mks-klipad50
Standard support
Minimal
Armbian 25.2.3 Bookworm Minimal / IOT
Kernel: 6.12.19, Size: 315.2 MB, Release date: Mar 19, 2025
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 25.2.3 Noble Server / CLI
Kernel: 6.12.19, Size: 475.1 MB, Release date: Mar 19, 2025
Additional information
Details about the MKS Klipad50 board and Sovol’s KlipperScreen:
Github project with issue tracker, discussions and custom images:
Flashing instructions:
  • Flashing with USB-eMMC adapter
  • Flashing without USB-eMMC adapter
After you download and boot?
armbian-config
Build Date: Mar 19, 2025
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 307.2 MB
RK3328 Rockchip
Build Date: Apr 9, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.22 SHA  ASC 318.1 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.22 SHA  ASC 329.6 MB
