Check or update before upgrade!
- On your board, edit the file
/boot/armbianEnv.txt
: Find the linefdtfile="rockchip/rk3588-nanopc-cm3588-nas.dtb"
and replace this line withfdtfile="rockchip/rk3588-friendlyelec-cm3588-nas.dtb"
, DO NOT REBOOT YET - Update your kernel as usual.
You only have to do this once, and only on existing installations. New installations and further update will not need any manual intervention.
(video instructions were not done by Armbian team, but it might help you get going)
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.14
Build Date: Apr 10, 2025
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
Minimal/IOT images with Armbian Linux v6.14
Minimal / IOT | ![]() |
SHA | ASC | 252.6 MB | ||||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 325.2 MB | ||||||
- join community forums
