nanopct3plus
  • You need to hold boot key and power/reset the device to force boot from SD card,
  • Shutdown doesn’t work properly. It reboots the board.
  • Devices, which memory number begins with SEC710 K4B4G16, need to do.:
  • https://forum.armbian.com/topic/7274-nanopc-t3-boot-troubles/page/3/?tab=comments#comment-83688
After you download and boot?
armbian-config
1000tx 2GB 64bit 8 core UASP bluetooth docker eMMC wifi wireguard S5P 6818 Nexcell
