nanopct4
Community maintained
  • UART is accessible on a standard connector but with unusual speed: 1500000
  • If you want to boot from your SD card you need to hold boot button while powering up/resetting
After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 245.1 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 336.4 MB
1000tx 4GB 6 core 64bit UASP bluetooth docker eMMC i2c i2s m2 usb-c usb3 wifi Rockchip RK3399
