After you download and boot?
armbian-config
Build Date: Feb 9, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.5 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.4 GB | ||||||
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.6 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
XFCE | ![]() |
KDE Neon | ![]() |
XFCE | ![]() |
Server / CLI | ![]() |
SHA | ASC | 506.5 MB | ||||||
SHA | ASC | 510.4 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 265.2 MB | ||||||
SHA | ASC | 260.1 MB | ||||||
SHA | ASC | 294.6 MB | ||||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 316.3 MB | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 322.1 MB | ||||||
- join community forums
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 251.6 MB | |
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 261.8 MB |
