After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Gnome | ![]() |
SHA | ASC | 1.1 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 232 MB | ||||||
1000tx 1wire 4 core 64bit battery docker i2c spi wifi wireguard Allwinner A64
- join community forums
