- Onboard wireless module (XR819) has poor software support so wireless connection issues are expected
- Hardware issues which manifest in stuck on reboot/power off on some boards (fix)
- Serial console is enabled by default on µUSB
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Server / CLI | ![]() |
SHA | ASC | 391 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 244.1 MB | ||||||
100tx 1wire 32bit 4 core CAN UASP docker i2c msata spi wifi wireguard Allwinner H2+
- join community forums
