nanopidou2
Community maintained
  • Serial console is enabled by default on µUSB
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 390.6 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.6 MB
100tx 1wire 32bit 4 core CAN UASP bluetooth docker i2c spi wifi wireguard Allwinner H3
