nanopik2
Community maintained
  • temperature readings are wrong. In reality, they are 15-20° lower
  • eMMC booting is not supported
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 259.4 MB
1000tx 2GB 4 core 64bit bluetooth eMMC wifi wireguard Amlogic S905
