- UART is accessible on a standard connector but with unusual speed: 1500000
- If you don’t have USB Type-C PSU, you can power the board via pins 4 (5V) and 6 (GND) of the 40-pin GPIO1 header
- Powering related troubles are possible since USB Type-C is not PD-compliant
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 270.4 MB | ||||||
1000tx 1wire 2GB 4GB 6 core 64bit UASP bluetooth docker eMMC i2c usb-c usb3 wifi wireguard Rockchip RK3399
- join community forums
