nanopim4v2
Standard support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.12.13, Size: 324.6 MB, Release date: Feb 13, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble Gnome
Kernel: 6.12.13, Size: 1.2 GB, Release date: Feb 13, 2025
  • UART is accessible on a standard connector but with unusual speed: 1500000
  • If you don’t have USB Type-C PSU, you can power the board via pins 4 (5V) and 6 (GND) of the 40-pin GPIO1 header
  • Powering related troubles are possible since USB Type-C is not PD-compliant. In fact you have to use dumb 5V PSU or device won’t boot up.
After you download and boot?
armbian-config
Build Date: Feb 13, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.5 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 508.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 315.3 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 317.1 MB
1000tx 1wire 4GB 6 core 64bit UASP bluetooth docker eMMC i2c m2 pci spi usb3 wifi wireguard Rockchip RK3399
Build Date: Apr 14, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.23 SHA  ASC 254 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.23 SHA  ASC 283.6 MB
