- UART is accessible on a standard connector but with unusual speed: 1500000
- If you don’t have USB Type-C PSU, you can power the board via pins 4 (5V) and 6 (GND) of the 40-pin GPIO1 header
- Powering related troubles are possible since USB Type-C is not PD-compliant. In fact you have to use dumb 5V PSU or device won’t boot up.
After you download and boot?
armbian-config
Build Date: Feb 13, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.5 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.4 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.6 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
Server / CLI | ![]() |
SHA | ASC | 508.1 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 315.3 MB | ||||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 317.1 MB | ||||||
1000tx 1wire 4GB 6 core 64bit UASP bluetooth docker eMMC i2c m2 pci spi usb3 wifi wireguard Rockchip RK3399
- join community forums
Build Date: Apr 16, 2025
Minimal / IOT | rolling | 6.12.23 | ![]() | SHA | ASC | 253.5 MB | |
Minimal / IOT | rolling | 6.12.23 | ![]() | SHA | ASC | 265.7 MB |
