After you download and boot?
armbian-config
Build Date: Feb 11, 2025
Most stable mainline based kernel but not all features have been implemented yet.Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
Cinnamon | ![]() |
SHA | ASC | 1.4 GB | ||||||
XFCE | ![]() |
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.5 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
Cinnamon | MESA / VPU | ![]() |
XFCE | ![]() |
KDE Neon | ![]() |
SHA | ASC | 1.6 GB | ||||||
XFCE | ![]() |
Server / CLI | ![]() |
SHA | ASC | 461.9 MB | ||||||
SHA | ASC | 501 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 257.4 MB | ||||||
SHA | ASC | 261.8 MB | ||||||
SHA | ASC | 291.2 MB | ||||||
Build Date: Mar 6, 2025
Most stable mainline based kernel but not all features have been implemented yet.Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 330.4 MB | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 312.9 MB | ||||||
- join community forums
Build Date: May 5, 2025
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 237.4 MB | |
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 260.2 MB |
