nanopineo2
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 429.4 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.9 MB
1000tx 1wire 4 core 64bit UASP docker i2c i2s spi wireguard Allwinner H5
