After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Server / CLI | ![]() |
SHA | ASC | 428.3 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 231.5 MB | ||||||
1000tx 4 core 64bit UASP docker eMMC i2c wireguard H5 Allwinner
- join community forums
