nanopineoair
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 391.2 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.7 MB
1wire 32bit 4 core CAN UASP bluetooth docker eMMC i2c spi wifi wireguard Allwinner H3
