After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Server / CLI | ![]() |
SHA | ASC | 436.5 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 248.3 MB | ||||||
1000tx 1wire 4 core 64bit UASP docker eMMC i2c i2s spi wireguard Allwinner H5
- join community forums
