Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 435.9 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 247.9 MB
1000tx 1wire 4 core 64bit UASP docker eMMC i2c i2s spi wifi wireguard Allwinner H5
