- More info
- Powering related troubles are possible since USB Type-C is not PD-compliant
- Check quick review
- Enable video and 3D acceleration
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 260.4 MB | ||||||
1000tx 1wire 2GB 6 core 64bit UASP bluetooth docker eMMC i2c usb3 wifi Rockchip RK3399
