nanopi-r1
Community maintained
  • serial console is enabled on UART1, which is exposed on chasis,
  • mUSB console is also enabled for login
  • Bluetooth is not yet enabled.
  • One Ethernet device gets random MAC
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 392.9 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.7 MB
1000tx 100tx 1wire 32bit 4 core CAN UASP bluetooth docker eMMC i2c spi wifi wireguard Allwinner H3
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
