- Login console is enabled also on mUSB connector
- Known problem: reboot sometimes doesn’t bring the device back.
- Network devices are not managed by Network manager. Configure via /etc/network/interfaces
After you download and boot?
armbian-config
Build Date: May 21, 2025
Server / CLI | ![]() |
SHA | ASC | 465 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 253.4 MB | ||||||
SHA | ASC | 249 MB | ||||||
SHA | ASC | 256 MB | ||||||
1000tx 4 core 64bit docker wireguard Rockchip RK3328
- join community forums
