nanpi-r4s
Standard support
Minimal
Kernel: 6.12.15, Size: 269 MB, Release date: Feb 20, 2025
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 25.2.2 Noble Server / CLI
Kernel: 6.12.15, Size: 440.5 MB, Release date: Feb 20, 2025
After you download and boot?
armbian-config
Build Date: Feb 20, 2025
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 254.2 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 321.8 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
1000tx 4GB 6 core 64bit UASP bluetooth docker usb-c usb3 wifi wireguard RK3399 Rockchip
Build Date: Apr 15, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.23 SHA  ASC 252.1 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.23 SHA  ASC 264 MB
