After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Server / CLI | ![]() |
SHA | ASC | 448.6 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 267.7 MB | ||||||
- join community forums
