Nanopi R5S Single Board Computer
After you download and boot?
armbian-config
Build Date: May 31, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.5 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 515.5 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 269.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 260.2 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 294.7 MB
Rockchip RK3568
