nanopir6
Standard support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.1.99, Size: 296.9 MB, Release date: Feb 11, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble Gnome
Kernel: 6.1.99, Size: 1.4 GB, Release date: Feb 11, 2025
If you are having a NanoPi R6C variant, replace fdtfile=rockchip/rk3588s-nanopi-r6s.dtb in /boot/armbianEnv.txt with fdtfile=rockchip/rk3588s-nanopi-r6c.dtb
After you download and boot?
armbian-config
Build Date: Feb 11, 2025
Most stable mainline based kernel but not all features have been implemented yet.
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.5 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 489.3 MB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 499.3 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 252.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 247.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 297 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 315.4 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 313.8 MB
Compatible
Nanopi R6C
Rockchip RK3588
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.1.115 SHA  ASC 246.6 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.1.115 SHA  ASC 260.1 MB
