Standard support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.12.13, Size: 269.5 MB, Release date: Feb 13, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble XFCE
Kernel: 6.12.13, Size: 1.3 GB, Release date: Feb 13, 2025
In case you are experiencing reboot troubles, make sure to update u-boot. How? Run this command as root:
armbian-install -> "Update bootloader"
After you download and boot?
armbian-config
Build Date: Feb 13, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 486.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 246.8 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 329.4 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 342.3 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 542.6 MB
1000tx 1wire 4 core 4GB 64bit UASP docker eMMC i2c i2s spi usb3 wireguard Amlogic S905X3
Build Date: Apr 16, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.23 SHA  ASC 275.5 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.23 SHA  ASC 281.3 MB
