odroidn2
Standard support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.12.13, Size: 265 MB, Release date: Feb 13, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble Gnome
Kernel: 6.12.13, Size: 1.2 GB, Release date: Feb 13, 2025
  • some people are having troubles with booting with Petitboot loader. In case you have troubles too, you need to disable Petitboot by running fw_setenv skip_spiboot true in the command line of Petitboot
  • On modern kernels adding “video=HDMI-A-1:1920x1080M@60D” to boot /boot/armbianEnv.txt (extraargs=) should force HDMI to 1080p instead of the 4K native resolution.
After you download and boot?
armbian-config
Build Date: Feb 13, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 485.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 246.9 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 316.5 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 341.7 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 541.5 MB
1000tx 2GB 4 core 4GB 6 core 64bit eMMC spi flash usb3 wireguard Amlogic S922X
Build Date: Apr 9, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.22 SHA  ASC 256.4 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.22 SHA  ASC 263.1 MB
