Olimex Lime
Community maintained
After you download and boot?
armbian-config
Build Date: Dec 11, 2025
Debian 13 (Trixie) Minimal / IOT SHA    ASC 260.2 MB
100tx 1wire 2 core 32bit CAN UASP battery docker i2c i2s nand sata spi wireguard Allwinner A20
