lime2
Community maintained
After you download and boot?
armbian-config
Build Date: Mar 27, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 241.5 MB
1000tx 1wire 2 core 32bit CAN UASP battery docker eMMC i2c i2s sata spi wireguard Allwinner A20
