oneplus-kebab
Standard support
Make sure to check flashing guide!
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.11
Build Date: Nov 24, 2024
Ubuntu 24.04 (Noble) Gnome SHA    ASC 33.9 MB
Ubuntu 24.04 (Noble) Gnome (rootfs) SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 36.1 MB
Ubuntu 24.04 (Noble) KDE Neon (rootfs) SHA    ASC 2 GB
Snapdragon SM8250
