Community maintained
  • UART has unusual speed: 1500000
  • Make sure to add large heatsink
  • Powering related troubles are possible since USB Type-C is not PD-compliant
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 250.5 MB
1000tx 4GB 6 core 64bit UASP bluetooth docker eMMC i2c pci usb-c usb3 wifi wireguard Rockchip RK3399
