Standard support
Minimal
Armbian 24.11.1 Bookworm Minimal / IOT
Kernel: 6.6.62, Size: 241.3 MB, Release date: Nov 28, 2024
SHA hash | PGP signature
Stable user space packages
  • Images for non LTS version can be downloaded here
Ubuntu Noble 24.8.1 XFCE testing:
  • Boot ok, from both sdcard and emmc
  • HDMI ok, boot splash screen shows up
  • USB2 and USB3 ok
  • Gigabit ethernet ok
  • Wireless ok
  • Bluetooth ok (although a bit spotty and usual cohabitation issues with wifi)
  • Analog audio codec is ok
  • Reboot and shutdown work as intended
 Debian Bookworm 24.8.1 minimal testing:
  • HDMI ok
  • USB2 and USB3 ok
  • Gigabit ethernet ok, throughput is fine (~960mbps)
  • Wireless ok, throughput ok (~50mbps at 2.4ghz, but far from router)
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Nov 28, 2024
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Gnome MESA / VPU SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon MESA / VPU SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI MESA / VPU SHA    ASC 491.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 247.3 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 322.6 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 534.9 MB
Help Armbian Grow: Support & Join Our Team!
1000tx 4GB 6 core UASP bluetooth docker eMMC i2c pci usb-c usb3 wifi wireguard Rockchip RK3399
Build Date: Mar 30, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.21 SHA  ASC 269.2 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.21 SHA  ASC 266 MB
