- In order to run Kodi (
sudo apt install kodi
) with HW acceleration, you have to run kodi under gbm or wayland. - If you cannot boot Armbian from SD card, you need to erase SPI bootloader from stock OS
After you download and boot?
armbian-config
Build Date: Feb 15, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.5 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.4 GB | ||||||
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.5 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
XFCE | ![]() |
KDE Neon | ![]() |
SHA | ASC | 1.6 GB | ||||||
XFCE | ![]() |
Server / CLI | ![]() |
SHA | ASC | 485.9 MB | ||||||
SHA | ASC | 493.6 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 269.2 MB | ||||||
SHA | ASC | 247 MB | ||||||
SHA | ASC | 300.1 MB | ||||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 316.5 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1.1 GB | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 312.7 MB | ||||||
Kali Linux | ![]() |
SHA | ASC | 537 MB | ||||||
- join community forums
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 249.6 MB | |
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 259.1 MB |
