orangepi5pro
Community maintained
PCI support is broken on vendor kernel (6.1.xx) on versions higher then 24.8.1. Use this version and freeze kernel (armbian-config -> system) prior to updating OS. PCI works on other Rockchip 3588 devices, while fixing this on all represent expensive technical challenge which we will be able to proceed once your donations for entire project reaches at least 1000 USD per month. With Orangepi devices we have extremely high negative support budget. Alternative operating systems that relies on our work face the same problem. We appreciate for your understanding.
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.4 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 242 MB
Rockchip RK3588
