- USB3 sometimes doesn’t detect high-speed devices properly
- A heat sink is highly recommended if you want to run it at full speed
- Changing screen resolution
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.1 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 248 MB | ||||||
4 core 64bit UASP bluetooth docker spi usb3 wifi wireguard Allwinner H6
