For proper hardware support you need to edit /boot/armbianEnv.txt and add:
fdtfile=sun7i-a20-orangepi-mini.dtb
following by reboot.
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Nov 24, 2024
XFCE | ![]() |
SHA | ASC | 1.1 GB | ||||||
XFCE | ![]() |
Server images with Armbian Linux v6.6
Server / CLI | ![]() |
SHA | ASC | 418.6 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 239.6 MB | ||||||
SHA | ASC | 229.4 MB | ||||||
1000tx 1wire 2 core 32bit CAN UASP battery docker i2c i2s sata spi wifi wireguard Allwinner A20
