orangepione
Standard support
CLI
Armbian 25.2.2 Noble Server / CLI
Kernel: 6.6.72, Size: 404.9 MB, Release date: Feb 21, 2025
SHA hash | PGP signature
Stable user space packages
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 21, 2025
Debian 12 (Bookworm) XFCE SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 240.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 230.8 MB
100tx 1wire 32bit 4 core CAN UASP docker i2c spi wireguard Allwinner H3
Build Date: Apr 9, 2025
Debian 12 (Bookworm) XFCE stable 6.12.20 SHA  ASC 712 MB
Ubuntu 24.04 (Noble) Minimal / IOT stable 6.12.20 SHA  ASC 233.8 MB
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.20 SHA  ASC 243.5 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.20 SHA  ASC 254.5 MB
