- USB3 sometimes doesn’t detect high-speed devices properly
After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Gnome | ![]() |
SHA | ASC | 1.1 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 231.6 MB | ||||||
1000tx 1wire 4 core 64bit UASP docker i2c i2s spi wireguard Allwinner H6
