After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Minimal / IOT | ![]() |
SHA | ASC | 243.5 MB | ||||||
100tx 1wire 32bit 4 core CAN UASP docker i2c i2s spi wireguard Allwinner H3
- join community forums
