After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Minimal / IOT | ![]() |
SHA | ASC | 238.2 MB | ||||||
100tx 1wire 32bit 4 core CAN UASP docker eMMC i2c i2s spi wifi wireguard Allwinner H3
- join community forums
