orangepipcplus
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 24, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 243.9 MB
100tx 1wire 32bit 4 core CAN UASP docker eMMC i2c i2s spi wifi wireguard Allwinner H3
