Orange Pi PC2
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 237.4 MB
1000tx 4 core 64bit UASP docker i2c spi spi flash wireguard Allwinner H5
