Orange Pi Plus
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.8 MB
1000tx 1wire 32bit 4 core CAN UASP docker eMMC i2c i2s sata spi wifi wireguard Allwinner H3
