orangepiprime
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 238.1 MB
1000tx 1wire 2GB 32bit 4 core 64bit UASP docker i2c spi wifi wireguard Allwinner H5
