Orangepi R1
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 393.7 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 245.5 MB
100tx 1wire 32bit 4 core CAN UASP docker i2c spi spi flash wifi wireguard Allwinner H2+
