After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.1 GB | ||||||
Server images with Armbian Linux v6.6
Build Date: Nov 25, 2024
Server / CLI | ![]() |
SHA | ASC | 453.8 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 224.3 MB | ||||||
SHA | ASC | 240.4 MB | ||||||
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 300.6 MB | ||||||
Kali Linux | ![]() |
SHA | ASC | 512.3 MB | ||||||
1000tx 4 core bluetooth docker usb-c wifi wireguard Allwinner H616
- join community forums
