After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Minimal / IOT | ![]() |
SHA | ASC | 232.2 MB | ||||||
1wire 32bit 4 core CAN UASP bluetooth docker eMMC i2c spi wifi wireguard Allwinner H3
- join community forums
