orangepizero2w
Community maintained
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 20, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 241.3 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 300.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 516.8 MB
Allwinner H616
