The 26 pin headers on Orange Pi Zero3 provides the following interfaces:-
- 3 I2C
- 2 UARTS
- 2 PWM
- 1 SPDIF
- 1 I2S
- and 1 SPI with 2 CS pins.
The pwm, spdif and i2s support is not there in kernel yet and hence overlays for them are not yet available. We have added overlays for i2c and uart. The spidev1_0 and spidev1_1 needs some editing and will be fixed in the future. When using the overlays, user should make sure they don’t enable overlay for features that use the same pin as this can cause conflict and either only one of the conflicting overlays or none of conflicting overlays will work. Its easy to fix it though as one can just disable it again from armbian-config.
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.1 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 250.1 MB | ||||||
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 310.8 MB | ||||||
Kali Linux | ![]() |
SHA | ASC | 517.7 MB | ||||||
- join community forums
