After you download and boot?
armbian-config
Build Date: Aug 14, 2025
Most stable mainline based kernel but not all features have been implemented yet.Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.5 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
XFCE | ![]() |
Cinnamon | ![]() |
SHA | ASC | 1.4 GB | ||||||
XFCE | ![]() |
Server / CLI | ![]() |
SHA | ASC | 523.2 MB | ||||||
SHA | ASC | 677.5 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 274.6 MB | ||||||
SHA | ASC | 258.4 MB | ||||||
SHA | ASC | 272.7 MB | ||||||
SHA | ASC | 243 MB | ||||||
SHA | ASC | 266.8 MB | ||||||
Build Date: Jun 26, 2025
Most stable mainline based kernel but not all features have been implemented yet.Distro | Application | Torrent | Integrity | Size | ||||||
Kali Linux | ![]() |
SHA | ASC | 557.2 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1.1 GB | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 318.9 MB | ||||||
Home Assistant | ![]() |
SHA | ASC | 332.5 MB | ||||||
1000tx 16GB 1wire 4GB 64bit 8 core 8GB CAN UASP bluetooth docker eMMC i2c m2 mpci msata pci sata spi spi flash usb-c usb3 wifi Rockchip RK3588
- join community forums
Build Date: Aug 31, 2025
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 247.8 MB | |
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 267.2 MB |
